Is there a way to change the profile in the Ion for a Mac700 so when you sneak enter in a cue you only lose the intensity rather than all other parameters?
thanks!
thanks!
There's no way to change the profile but a few things which may help.
Using highlight which I think is under More SK (soft keys) on an Ion to bring a channel to full for focusing. To use highlight, [Channel X] {Highlight} [Enter] Or [Highlight] [Enter] [Channel] [Enter]. After focusing you'll need to come out of highlight mode.
If you want to use sneak, Shift +Custom (Encoder Page button) will post intensity on the command line which you can add sneak to.
And the opposite to what you want, double hitting sneak will sneak everything but Intensity.
