Calibrating Scrollers on ION with new 2.2 Software?
The manual that I have (2.0) says
Step 4: If you are in coarse mode, press the encoder the switch to "Fine" mode. The {Calibrate} touchbutton will appear as one of the scroller buttons in the LCD."
Step 5: Continue adjusting the frame in fine mode until the frame is centered in the desired position.
Step 6: Press {Calibrate} in the encoder LCD. The new center position is now stored for the selected channel.
Problem - If I press the encoder, the {Calibrate} LCD button only stays lit for as long as I hold down the encoder. If I hold down the encoder and try and move the scroll, absolutely nothing happens. If I use "Shift" and the encoder, the movement of the scroll is still too much to do any fine calibration, and the {Calibrate} button doesn't seem to do anything anyway (I have tired both the LCD touchbutton and the button in the ML controls.
What gives?
