NET3 IO Gateway setup
I need to connect small analogue console on stage o Eos console. Just to bind faders of analogue console with real submasters of Ion. So all movements of faders on small console will do the same with submasteres. Except the WiKi article on Webpages I did not find anything about this topic. First I was thinking it can be done via Remote analogue port on back of console. But later I found it is just "digital" input for trigering not input that can "read voltages".
Will this setup work for me?
How I can tell console, I get analogues from Gateway, not local port? It will be usefull to add this to guides of console or gateway...
  • You are correct - you'll need a Net3 I/O Gateway in order to get analog input. The back of the consoles (Ti, Gio, Ion, Element, RPU3, Ion RPU) have four contact inputs (on/off) and one relay with NC and NO contacts.
    The inputs are configured in Gateway Configuration Editor - pay special attention to the on/off or analog setting for the ports. It also requires an external 10V power supply - the gateway doesn't source any voltage for analog.
    The screenshot looks correct for a gateway in ACN Group ID 1 and the contacts configured for addresses 1 and up.
