URGENT High End Systems DL3 on GIO
Hi
Has anyone ever used the DL3's on GIO or EOS? I am really struggling here - cannot get them to do anything - not my area of expertiese
Need help and advice really urgently
Thank you
  • can't get them to do anything is big.... have you been able to set a start address and get the master profile to pan and tilt them? Are you familiar with using media servers on the Eos systems? There are multiple profiles that need to be patched in order for the DL3 to be fully used. You will need one channel for the control profile, one for the global, and as many channels as you have layers each patched as a layer. You also need to know what version of DL3 you are patching. Hope this helps
  • Hi, Sorry - I realise that was a bit vague...it turns out that it was a dodgy fixture -= tried a different unit and all was easy and worked as I was expecting it to! It did have me guessing though! Thanks for the help Declan
