How Can I use quick layout on magic sheet?
I can use part of quıck number. Too useful for regulary changing to chanel number..
I couldnt understand normal and quick layout ..
I tried more times .. First ( target=chanel , start=1, increment=1)   I can give chanel number 1,2,3,4,5 .... With mause..
Can I give chanel,adres number to all fixturies without mause ? I need that.. Because there are too mixed number on magic sheet . my plans has 376 dimmer adress..
THanks too experts for replies from now ..
  • I ll say more clear.. First of all what will I do on make a plan on magic shett.. I know I should make fixturies chose and draw out .. After should I give adress ? Should I chose chanel (by adress) ? Should I make patch ? Please give me advice step by step.. Thanks From now
  • There currently is not way to use the magic sheet tool without utilizing a mouse or touch interface to lay the actual magic sheet out. There is no auto-create magic sheet option as that is not something we could accurately predict. What I would recommend is to make your first symbol exactly how you like then array or copy and paste that object elsewhere to the sheet. Create your symbols first, lay them out on the sheet then use the Quick Number tool to assign channel numbers as needed. This will pull whatever the address is from patch. Hope this helps.
