ION Fader Wing Wobbles.
Why does my ION Fader wing wobbles all of a sudden? Are the feet adjustable?
  • The feet aren't adjustable.
    The most likely causes would be:
    1) It's sat on something (cable, old script etc) or the table is not flat.
    2) The screws holding it to the main part of the Ion are loose (or missing), in which case you want to tighten/replace them ASAP as they prevent it from disconnecting from the main part.
    3) One of the feet is missing or been damaged - eg cracked off the rubber while sliding it.
    Your local ETC dealer can supply new feet.
