Eos doesn't sync with master on first try
So we are running an Eos as a backup to an RPU as the master. The RPU is on, and I turn on the Eos, it doesn't find the master. If I go to troubleshoot it does not show any available masters. Usually if I exit back out to the shell and hit 'backup' it will then find the master. And even when it does find it, it's not right away, it could be sitting for a little while, which while not that long, is still much longer than it ever use to take.
Just curious if anyone else has run into similar? It mostly worries me if it keeps taking longer and longer, or that it might stop syncing all together.
