External Monitor size Ion
Hi there,
Are there any limitations for the external monitor sizes or screen resolution. I've worked on 19-inch monitors while programming, but on tour I wan't to use one smaller monitor (15 inch). But when I connect this, the cue screen is being cut off, so I can not read the labels any more.
Is there any way to adjust this. Or to adjust the way I see this screen. I'm not really interesterd in Focus/Color/Beam timing, so if I can collapse this?
 Hope to hear.
Remko
Conny janssen Danst
Rotterdam, Netherlands
  • You can use a 15 inch monitor, as long as the monitor can support 1280x1024 resolution (which most do not).
    We do plan on making many of the displays much more customizable which would allow you to use smaller display resolutions, but for the current release the requirement is 1280x1024 minimum for display resolution.
    -D
