I understand that Shift+Time will put a discrete time on a tombstone while you are pressing them. Is there anyway to have the discrete time always on the tombstone?
If I´m right in 2.2 discrete times are shown on a tombstone while pressing time button WITHOUT shift and this view can be "locked" by pressing shift AND time. But as discrete times are shown in the same area of the tombstone where usually the channel-Level is shown you won´t have Information about the intensity till you switch back...
yes, you can. the way depends a bit on the console. the reason is that Gio, Eos and Eos Ti have two Time buttons, Element and Ion have just one.
Gio, Eos, Eos Ti:
short-term: keeping the right hand Time pressed
long-term: Shift+ the right hand Time will latch the discrete time visibility. Shift+ the right hand Time to unlatch
Element, Ion:
short-term: Shift+Time
long-term: Shift+Time Time (time double click). same again to unlatch.
i think you can use the Ion/Element method on Gio/Eos/Ti as well with the left-hand Time button.
