Hello.
Found a little bug today.
Screen 1 has 3 frames. Each with a PSD. List 1, List 2 and List 3. If I click on a cue number in list two, the command line changes to 2/cue number. If I then click back to cue list one, it only enters the cue number, not the list number, so i end up with either a cue from list 2, or an error for a cue that doesn't exist.
if I click a cue in list 3, I end up with 3/ in the command line and the same problem occurs.
The only way to get back to list one is to click in that tab/frame and then type cue 1/ enter.
Then to make it more annoying, after I hit enter on cue 1/, it thinks for a second and then selects the first cue in the list (0.5), not to the active cue on list one.
To get back to the active cue, I have to wait until the board op takes the next cue to get lined back up. Hitting live or or shift live doesn't seem to get be back in sync.
The final issue maybe be because the RVI master playback is set to 0, while the main console is set to 1.
This is all on an RVI 2.2.0.9.0.96. Separate user from any of the consoles.
