Out button --- strange behavior
One of my students programmed the current show and now whale we hit the out button, channels go to 15% instead of 0%.  Any suggestions on how to overcome this?
  • It is always a good idea to let us know the console you are using and the software version it is running. I haven't heard of this happening, but the first thing to try would be to restart the console and see if that fixes the issue.
    If the problem is still happening make sure you save your show. Next exit to the shell and save the logs to a usb stick just in case ETC requests them if your problem doesn't get fixed. After that go to the maintenance section in the shell and do a deep clear. This clears persistent memory and resets the screen layouts. You'll have to reload the show when you go back into the software. Let us know if that fixes the issue
  • but At 0 Enter works? Out will take a value to its home value. I would check the fixture personalities or the home preset
