Eos to Q-Lab Midi Trigger
I am trying to set-up a Midi network in order to trigger Audio's Q-Lab rig.  Device settings are listed below.  From the very few articles I have been able to find, I believe what I need to do is to set up a secondary cue list (Q1/ is generics, Q11/ is movers, Q16/ is midi) with cue numbers that match the audio cues (Q16/100 should trigger Audio Q 100). I believe I need the secondary cue list because the audio cues do not line up with the LX cues trigger cues  (i.e.  I need LX Q5 to trigger Audio Q100).
1st Problem:  the box that audio has connected to the Show Control Gateway is not indicating Midi activity.  (The gateway is online)
2nd Problem: is this the best way for me to be sending midi triggers?
3rd Problem: why is the top hit on the support website an article written in 1992?
AUDIO/Q-Lab
-listening to ch. 16
EOS Ti (2.2.0.9.0.66)
-MSC Transmit Channel: 16
-ACN Midi Tx ID: 1
-String Midi Tx: Enabled
-Midi Cue List: 16
Midi Show Control Gateway
-ACN SMPTE Rx ID: 1
-ACN Midi Rx ID: 1
-ACN Midi Tx ID: 16
