We had a couple surprising syntax results (2.2), and I'm curies if they are expected behaviors.
The Cue List Index appears to be the only target list where the listed items are not implied. For example, [2] [enter] selects cue 2 of the active cue list, rather than cue list 2. This threw is when switching from another target tab. For example, is the Intensity Palette tab is active, [cue] [2] [enter] selects cue 2 of the active cue list in the Cue List Index tab, rather then cue 2 in blind channel. I would expect [cue] [2] [/] [enter] would be the syntax to switch to the Cue List Tab.
On the other hand, I may be thinking of the Cue List tab incorrectly. I'm seeing it as a way to see and adjust settings for multiple cue lists, but should I view it more like the edit view for the playback tab, more like the blind cue list screen in O2?
We also found that the list posted by Select Last remains the same, regardless of the implied target. For example, in a channel tab, set 5 @ 50. Switch to the Presets tab. Select Last posts Preset 5. Is that correct? I would probably expect Select Last to post nothing. To be fair, it was only an issue because the wrong tab was active.
Josh
