Network error 10013 when trying to ping console
Trying to connect nomad to a console on my network as a client. I wasn't getting any response so I went into the shell to see if I could ping out of there to the console. Got an error right off the bat saying "could not create socket" error 10013.
Same issue if i do it with the router. I can ping just fine from the computers command prompt, I'm just not getting out through ETC software.  Everything that is required to do networked/multiconsole is checked appropriately, console and nomad are same build, all services I'm not using are unchecked... etc. Basically I can't find anything wrong in the setup and I know I have connection because i can ping back and forth on the computer end. Is there any know issues that have these same symptoms? I'll try and attach a show file the second I can but mid show load in, was hoping to get some mild answers that will help me solve the issue.
