What firmware version should the universal fader wings be on?
I'm running an Ion console, recently updated to 2.2, connected to two 2x10 fader wings.  The wings are still on firmware v.1.  The wings are causing issues, in that I if I start up the console while they are connected, the console gets stuck starting up.  I have to kill the console, unplug the wings, and restart again.  The fader wings are also having an issue where the text on the control screen (Where it says Electronic Theatre Controls when not getting input from the console) is off; meaning that the top have of the letters are where they should be, but the bottom half have moved a half inch to the left.  This problem does go away when the console is up and running, so it's not causing issues there, but it's also not... right...
I have checked the firmware update dialog under the maintenance menu, but the update option is grayed out, which is why I'm here.
