.CSV Exports missing data for Mark, Intensity Block, etc
When I export .csv files from v2.2 (either as one massive CSV or as Fast Focus Pro individual CSVs) and look in the Targets table at the Cues, the csv seems to be missing Mark Flags, Intensity Block Flags, and maybe more? Are others seeing this too?
Also, as a bit of a feature request, I wish that the CSV export had empty fields for timing attributes that are hidden on the Playback Status Display. For example, if I have a cue with only intensity moves and an intensity time of 2, the Focus, Color, and Beam time fields, along with all the Delay fields (Intensity and NPs) should be empty fields in the .CSV just as they are on playback status. Technically, I can understand why the desk thinks a delay of 0 is the same is no delay and that a cue may technically have a color time even if there are no color moves, but this makes it really hard to make full use of the .CSV export because there is no way to know if there is no beam time, or a 0 beam time from just the targets table.
