Hello, ETC. Profile fix needed, or possibly help debugging if a software programming corruption. I've just installed the latest fixture library, 10.2.x, build 50, and the problem remains. Running 2.2 (build 96, release version), and about to go into tech week for a middle school musical. There is a partial workaround, but with a student running the lights for the show I'd much rather resolve the issue.
I patched a Chauvet Strike 324 in 5ch mode to DMX 2/501-505 on ch 79.
1) Double-clicking the (unlabeled) Intensity box and setting to 0 does that.
2) Pressing [Out] sends the fixture to FL. Reset to 0. This is a seriously bright fixture; pretty jarring!
3) Pressing [Goto Cue] [1] [Enter] (channel not listed as active in Blind) sends fixture to FL.
4) Pressing [Goto Cue] [Out] [Enter] sends fixture to FL.
5) I can assign the channel 0 Intensity in every cue (working in Cue only mode currently), or create a macro to do this, but this does not solve the [Goto Cue] [Out] problem, and I use that a lot. Would love a fix ASAP. Timeframe?
I also ended up in a state where console commands were not reaching the rack (no response to faders or direct channel commands; blackout not activated, grandmaster at FL). Restarting the software did not resolve this. I had to reboot the console.
Note also that the beam control names do not match those printed in the Chauvet manual:
a) Chauvet 5-Ch "Flash Intensity" is ETC "Intens", OK.
b) "Flash Duration" is ETC "Strobe Duration".
c) "Flash Rate" is ETC "Shutter Strobe".
d) "Special Effects" is ETC "Strobe Mode".
e) "Pixel Control Macros" is ETC "Effect Macros".
It all ends up being pretty obvious, but is there a good reason why the labels don't match up?
Please advise timeframe for library update, or how else I should approach this. Thanks,
Abe Hendin
The Abraham Joshua Heschel School
