creating a fixture in the EOS family
In the fixture library each fixture has a certain number of channels. Within each channel there are a certain number of "ranges". Within the "ranges" section there are a certain number of functions. Each function has two Min and Max sections, one for User. The default values start as 0 - 255 under the Min - Max column and 0  - 100 under the user Min - Max. Couple of questions:
1) Is value 100 the same as 255? If so why 100 instead of 255? if not what does it represent?
2) When would the values in these two sections not be identical to each other? Just an example so I can understand what they represent. It seems each time I have created a fixture I just create the columns identical to each other otherwise I get an error and can't exit.
