Hi JK Pitzer,
I agree with what the others have said about automation and light boards, but just to make sure we are all on the same page... When you say turntable, are you speaking about a large turntable on the set (moving scenery), or a record player?
Please note, the DMX512 standard specifically states that DMX is not suitable for hazardous applications.
It was designed for lighting control where the worst that could happen was a light might flicker.
If an accident occurred then you'll probably end up having to justify the decision in court.
The judge will read paragraphs 1.3 through 1.5 of the DMX512 specification and say "Why did you decide to do this?"
When considering the use of DMX (or similar) to control anything that's not a 'normal' luminiare, you need to know how you'd answer that question.
For something small or out of the way like a normal-sized record player, mirrorball etc, then justifying DMX control is probably easy.
- All you have to do is make sure that nobody could get hurt if it were to spin out of control at the wrong moment.
If it's something larger, then consider what might happen if it moves when it shouldn't?
Anyway:
Subs are configurable. Hit [Sub][Sub] to open the list of subs and check/alter their configuration.
Assuming the channel is patched as a dimmer, the defaults for a new Sub set the button to be an instant Flash button and the fader to be a simple proportional one:
- Additive, Proportional, HTP, Up:0, Hold:Man, Down:0
Remember that the bump button is the bottom one.
Note that if the channel is Parked, Inhibited etc then those will override/limit the sub.
