Change Size/Rate of multiple running Effects at once - Effect Status Display
when multiple Effects are running, I can e.g. [Effect] [901] [+] [902] and then tap the Softkeys for {Rate} or {Size} and change those values for more than one effect at the same time using the commandling. This is not possible with the encoders though.. Any more infos on this ?
(running Software 2.2.1)
Cheers from Korea,
Matze
