Is it possible to view pan/tilt values in decimal or percent instead of degrees?
I'm working in converting MLs from a GrandMA to the EOS, but the information is presented in percent on the MA and degrees on the EOS. Without having to make a custom fixture, is it possible to view the degrees in a percent format? I would like to be able to toggle between the two if possible.
