Fixture Profile request
  Hello on a chilly Friday evening!  I've just been told that a show coming in Monday (yes unfortunately,  2 days away) is bringing in par LEDs called Expolite Studio Par II.  I don't see them in my fixture library.  The only thing I know about them is they are supposed to take 6 dmx channels; intensity, red, green, blue, colour macro, scroll/strobe.  I certainly don't expect a profile by Monday, but if anyone has come across these or can suggest anything but building a profile on the fly it would be grand.  Could be we're not cueing until Tuesday afternoon, but I'm not counting on it.
Heather
  • Hi Heather. I would make a copy of the personality Generic > LED IRGB and then add two parameters at the end. Could be quickly done and quite straight forward
  • I agree with Ueli. In order to have a profile made we need the manual for the fixture. I was able to find it in German, which we should be able to make work; however, if you have an english language version that you can send our way it would be greatly appreciated.
  • I should note I did submit this with the German manual, but there is no way it can be ready by Monday.
  • I will try copying the IRGB generic as suggested and see what to do about the other 2 parameters. I too have only been able to find a German manual online, but I was forwarded a word document by the rental house which I will copy and paste below. Tis a bit of a rough translation and I'm not sure it will be much help. Sorry it makes a long post, but this is all I've received and of course everyone (but ETC!) is closed now. Thx so much and I appreciate your attention.
    STUDIO PAR II 18x3W manual
    Thank you for the LED STUDIO PAR II 18x3W decided the innovative
    LED headlight for professional applications. With its extremely bright RGB LEDs, the unit can
    represent a total of more than 16.7 million colors shades. This makes it the ideal headlights both
    for stage and TV as well as disco, clubs, etc.
    Specifications:
    • LEDs: 18 x 3W RGB (3-in-1 Multi-LED)
    • Power consumption: 60W
    • Voltage: AC110V-250V, 60Hz-50Hz
    • Built-in Color Scenes & Sound Control
    • DMX-control: 6 channels (dimmer, R, G, B, Color Macro / Scroll & strobe)
    • Master-slave control
    • Dimensions: 31 x 23 x 22cm
    • Weight: 4,6 kg
    Configuration (LED display):
    Please note:
    When display is flashing mode and value by UP / DOWN button to change are.
    Important: After setting always confirm with the SET UP button!
    MODE 1: C000
    Press the MODE button to enter this mode ---- STATIC COLOR
    C100 RED: 00-99% brightness
    C200 GREEN: 00-99% brightness
    C300 BLUE 00-99% brightness
    CF00 STROBE: 00-99% speed.
    MODE 2: J000
    Press the MODE button to enter this mode ---- COLOR CHANGE "JUMP"
    J300 RGB: 00-99% speed
    J700 COLOR: 00-99% speed
    JF00 STROBE: 00-99% speed
    MODE 3: F000
    Press the MODE button to enter this mode ---- COLOR CHANGE "FADE"
    F300 RGB: 00-99% speed
    F700 COLOR: 00-99% speed
    FF00 STROBE: 00-99% speed
    MODE 5: Slav
    Press the MODE button to enter this mode ---- SLAVE MODE
    MODE 6: Addr
    Press the MODE button to enter this mode ---- DMX ADDRESS SETTING
    Connect a now a DMX controller to obtain the following functions:
    DMX channel assignment and functions:
    Channel 1 K 2 K 3 K 4 Channel 5 Channel 6
    0-4: Blackout (RGB)
    5-84: Color Sound2Light
    85-169: Color Jump
    Master Dimmer
    (0-255)
    RED
    (0-255)
    GREEN
    (0-255)
    BLUE
    (0-255) 170-255: Color Fade
    Strobe
    (0-255
