Dale, if you hold down the [Time] key (on an Eos the one near the data key), the display will toggle to show you any discrete timing used in a cue. If all of the timing is the same in the focus category, you will see the timing in a summary view. If the timing is different for various parameters within the category, you need to go to the table view, expand to see your categories and then use the time key.
Does that make sense? If you are having trouble navigating and remembering how to get around, I have a quick guide to navigation and displays I could send you. Just let me know.
Hope this helps.
Anne
Anne,
I'll check it out next time I'm at the console. The one thing I'm still struggling with on the ION is how to navigate the displays to find information I want. I would appreciate you sending the guide to me.
Dale.
