Untouched Parameters Keep Appearing in Cues
Hey everyone,
I've been experiencing some odd behavior on a few multi-parameter devices for a while now, so I figure I'd finally ask about it on here.
I have set of Chauvet Colorado 1 LEDs.  I'm programming a show and adjusting the color parameter only.  I do not touch the beam section at all, everything is Home.  (The fixures only use color and beam).  When I go to record a cue, everything works fine, except the beam parameter is recorded showing a blue "+" in the channel tile and a beam time on the cue list.  To fix it I just go into Blind and say Group 201 Beam At Enter and it goes away.  But this happens every time I record a cue, even if I don't even touch the fixtures at all.  Update does not have this problem, only when I use Record does untouched beam data come in.
Does anyone have an explanation for this? Or does anyone else ever experience this?  It's not a huge deal because I can clean it out in Blind, but still just a bit annoying because I like a clean cue list. :)
