Step Based Effect Issue
I've run into an issue with intensity step based effects.
It seems that as soon as I select "build", no matter what value I put in the OFF state, in Live it will go to 0. For example, OFF state is 50, lights go to zero.
When I put 0 in the OFF state (or select negative instead of positive with the above example) the channels stay at 0, no matter what the value of the ON state is.
This seems to only happen when Build is selected.
Have I stumbled into a bug, or am I doing something wrong?
On Nomad on a mac vers 2.2.1
