Nomad Crash when Ethernet connection enabled.
I've had an issue with Nomad Ver 2.2.1.0.13 where if I have my Ethernet card enabled Nomad crashes on bootup. Clicking on "Launch EOS Family" works fine. It's when I click on Offline or Offline w/vis that It crashes. If I disable the card, then click on offline or offline w/vis, then I'm golden. Once the offline starts, then I can re-enable the card with no issues that I have seen.
Running AMD 64 w/ Windows 7 - 64 SP1.
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    Eos.exe
  Application Version:    0.0.0.0
  Application Timestamp:    5457997c
  Fault Module Name:    KERNELBASE.dll
  Fault Module Version:    6.1.7601.18409
  Fault Module Timestamp:    53159a86
  Exception Code:    e06d7363
  Exception Offset:    0000c42d
  OS Version:    6.1.7601.2.1.0.256.48
  Locale ID:    1033
  Additional Information 1:    2e62
  Additional Information 2:    2e62b4d6682144cdaebb9ad18e1c86b2
  Additional Information 3:    9e13
  Additional Information 4:    9e13acaf97384a40bd337c57cb16a320
