Multiple Network Interfaces with Nomad
While writing this, the search engine finally kicked out some previous instances of this question, but there were no answers...how do you select between multiple network interfaces in Nomad? In all the other current (Net3) PC software I've used, there has been an option to select the interface somewhere in a menu. In the Net2 days there was a separate program which all the other programs referenced. Whether on my PC or my Mac, I often have multiple interfaces active for one reason or another and I need a way to direct the software to the correct interface.
  • Not sure if this helps or not, but I run Nomad Wireless with either an ION or EOS TI System, and a wired Ethernet to the Internet. All settings on both interface cards are set DHCP. Make sure that only the interface card, that Nomad is to use, has an IP Address starting with 10.101.***.***. Of course this will only work if one of the processors on the network is acting as a DHCP server.
    I may be shunned for suggesting this, but if you FB... https://www.facebook.com/groups/etceosprogrammers/
