Feature Request - Show File Size
Show files are getting progressively bigger due to Magic Sheets, many of ours are around 30Mb now which can take a long time to load!
There are a couple of things (probably fairly quick) which it would be great to add.
1. When you hover over an image in the picker, could it show it's file size as well as the name?
2. It would be great to have a quick file analysis in About which shows you the total of all your images so you know what's causing the bloat.
Cheers
Dan
