RFR skipping channels in channel check mode
I am having an intermittent issue with the Net 3 RFR. When in channel check mode it sometimes skips over 1-3 channels at a time. It does so when using the side wheel, the "next" button or the "back" button. On its worst day it can do the skipping 5 times within one system of 30 lights. Ch1, ch2, ch3, ch6, ch7, ch8, ch9, ch 13... On its better days it could skip once within the whole check. Rarely it can do a perfect channel check. What could be causing this? The screen always displays the correct channel thats on, I just see it quickly bump through others with a single click of "next". I haven't confirmed this yet but it may be worse when fresh off the charger or maybe its just a coincidence. Is there a reset button of a sort on it? looking through the special boot up menus I cant find anything like that.
Also it seems to have stopped going into its "sleep mode" when on charger or when left on for a long time. The screen and buttons stayed lit for at least three hours last night. Is there a setting somewhere for how long till it times out? What is that time supposed to be? Just trying to see if any other behaviors may be connected to the first issue.
