Fixture Profile Encoder Setup Information / Parameter Range Detail
I have a question regarding where encoder setup information is stored in fixture profiles. When I select a patched Apollo Smart Move DMX I notice that I get all the FX selector options in the ML controls on my console. That would lead me to believe that in the fixture profile for the Apollo Smart Move DMX there should be a bunch of ranges set up under the FX parameter for those various different FX options. I copied the fixture profile so I could take a closer look at it. Under the DMX 1 parameter, which would be used to select the various FX options, I do not see any ranges defined. I would have expected to see ranges defined for such things as "Home", "Clockwise Rotation", "Counterclockwise Rotation", etc. Where is the information that is showing up in my ML controls stored? Is it editable? Why does it not show up in the ranges of the applicable parameter? I don't have a pressing need to be able to edit this information, I'm mostly trying to expand my knowledge on how this is handled in Eos. In other fixture profile editors I have used, such as for LightFactory, there is an aspect of each fixture profile that pertains to the setup of the encoders for that profile.
  • Hi there,
    This is a current limitation of the fixture editor that happens when there are multiple possible ranges that change based on other DMX parameter levels. The data is in there, but the fixture editor does not have the interface to show this. When this occurs, we gray out values in the editor, restricting editing.
    If there is something wrong with the profile, definitely let us know and we can apply the fixes and get it in a fixture library update.
    Hans
