direct select channels
     I tried to usethe direct selects for calling up channels and ran into a bit of a issue, and I was wondering if it is suppose to be acting this way or not.  When I select groups from the direct selects, they are de-selected as soon as I make another group selection, after I've assigned the original group a %.( So I select Group 1 and give it an intensity value.  Group 1 is then de-selected when I select Group 2.)  But that is not how the channels direct selects act.  When I select a channel and give it a value(i.e 1@ 50%) it remains selected even once I make another selection.  So when I select 2 and give it a %, channel 1 is still on the command line and gets the % I gave to channle 2.  It does the same thing when I've selected a channel and given it a % and then try to select a group to give another % to.  (e.g. channel 1 @ 50% enter.  then I select group 2 to go to 25%, but instead of just group 2, the command line reads chan 1+Group 2)  It would be great if in a later version of the software if the direct selects for the channels worked the same way as they so for the groups.
  • Anne Valentino:
      When using the direct selects, selecting new channels will always add to any other channels you have selected.  If you want to de-select your previous selection, you double-click the new one.  Channel selection from the command line is always a replacement, unless you preface the channel selection with a + or a -.    In this manner, you always have both options... to add to what you already have or to replace what you already have.
    I also read somewhere that group direct selects act differently.  If you select a group and give it an instruction, then select a different group, the first group will be cleared from the command line.  I'm pretty sure the post also said that the behavior of one is going to be changed to match the other, but I don't remember which one was going to remain unchanged.  I'd point you in the direction of the post, except I can't find it (sorry).
    Hope that helps - cheers
    [edited by: BrentFJ at 10:08 PM (GMT -6) on Fri, May 09 2008]
