Bug Report in V2.2.1.9.0.13
In fixture builder; add new control attribute - automatically assigns new lines; with, height, z - but click new past Z and software immediatley exits into shell.
  • Hi Matt,
    I'm not able to reproduce this. I'm assuming that to reproduce, you create a new fixture, go into Edit mode, and click "New" repeatedly? Then, once 'Z' is on the screen and you click New again, it crashes?
    If you can still reproduce this, can you save logs right after it exits to the shell and send them to hh<at> etcconnect <dot> com, referencing this forum post?
