Hi, I need a working fixture profile for this. Here's the manual with DMX attributes: http://www.chauvetlighting.com/products/manuals/Intimidator_Spot_355Z_IRC_UM_Rev1_WO.pdf
I need it by June 10 if at all possible.
According to the Fixture Release notes this was added to the library on November 24, 2014, both 15 and 9 channel modes. It ought to be in the latest library.
https://www.etcconnect.com/Products/Consoles/Eos-Family/Eos-Ti/Software.aspx
Manufacturer Chauvet
EOS Name Intimidator_Spot_355Z_IRC_15ch
Carallon Name Intimidator Spot 355Z IRC 15 channel
Revision 0 (24 Nov 2014)
Details [DMX Tested] [DMX Footprint 15]
Channels 1&2:Pan, 3&4:Tilt, 5:Position MSpeed, 6:Color Select, 7:Gobo Select,
8:Gobo Index/Speed, 9:Beam Fx Select, 10:Edge, 11:Intens, 12:Shutter
Strobe, 13:Position Blink, 14:Macros, 15:Zoom, V:Color Wheel Mode,
V:Gobo Wheel Mode, V:Gobo Mode, V:Strobe Mode Lamp Controls Pan Reset,
Tilt Reset, Color Wheel Reset, Gobo Wheel Reset, Gobo Reset, Effect
Wheel Reset, Focus Reset, Fixture Global Reset
User Notes
Set menu option Run Mode to 15CH for this personality Ch 1 - Set menu
option Pan Angle to 540 for this channel to work correctly Ch 3 - Set
menu option Tilt Angle to 270 for this channel to work correctly.
Written from quick reference guide rev 1
