I would like to see the actual value of the DMX output on my magic sheet, rather than the value in the channel. I set the target to Address, but it displays the channel intensity, not the DMX value being output. I've tried other combinations (e.g. channel by address), but I can find no way to display the actual output. This is particularly handy when using other than standard curves or when a channel is parked. I know you can get this on other displays, but how do you get it on a magic sheet?
