How can I see the changing channel values when using intensity palettes?
When I set a channel to an Intensity Palette and GO to that cue, the display immediately shows the label for the Intensity Palette as the channel intensity instead of the changing value of the channel, eventually stopping at the Intensity Palette assigned value.  I know the channel is fading up to the correct intensity, but the display does not show the value as it fades up.  If I use an absolute value instead of an Intensity Palette, it correctly shows the channel counting up to the absolute value.  Other than Make Abs on the channels in question, how can I get the console to display the instantaneous value instead of the final value of the Label?  If I don't Label the palette, I get "IP 1" instead of the channel value.  I would like to watch the display count up (or down) until it reaches its final value and switches to the Intensity Palette Label.
