I have a square on a magic sheet set to link to channel color. I select the square and set its color with the gel picker to R347. The color swatch on the gel picker looks similar to the Rosco gel, but the color on the magic sheet square is totally different. The Color Picker shows the color similar to the magic sheet color (also incorrect). R347 has considerably more blue than I am seeing on either the magic sheet square or the color picker. The Gel picker shows a very different color, which is approximately correct for R347.
This happens for other colors as well (e.g. R358, R310, R348), some but not all. In most cases, the color picker seems to match the magic sheet, not the gel picker. (i.e. wrong too) What am I doing wrong? I tried making the base color in the magic sheet white, black, and various colors in between, but nothing seems to make the magic sheet match the gel picker. The instrument is patched as a D40 Vivid.
I realize the colors cannot match the gel exactly, but these are not even close. I'm willing to live with the colors in the gel picker; they're close enough.
Note: The color picker shows these colors for R347: Red 100, Red-Oran 24, Amber 0, Green 0, Cyan 0, Blue 0, Indigo 22, Hue 330, Sat 71 (It looks to me like the hue should be closer to 265 than 330.)
