Strange OSC command for 'Fan'
The OSC commands are usually, easy to guess from the list in the magic sheet editor, however, fan is strange being:
'/eos/key/fan_'
It requires the underscore otherwise EOS doesn't recognise it. Is this a bug or is it intended? Also, if you can't find the correct syntax for an OSC command, the macro editor may be of help, which gives the correct commands in the editor.
Cheers,
Joe
