Macro button on Eos
I'm moving from a Geo to an Eos and I usually program the macro key 821.  I was going to program that same blank button on the the Eos, but I couldn't find what macro number it is.  All the resources I have found are for the Geo or Eos Ti. Can anyone tell me what macro number that is or how to get to it otherwise?
  • the empty button on the Eos (between Label and Note) can't be mapped to anything. on an Eos classic you only get macro buttons 801 through 803. the usual work arounds are macro direct selects, a magic sheet or an x-keys. NB with 2.3 you can have one column of direct select buttons in a frame somewhere on a display. maybe 10 high, 1 wide would fit nicely.
  • Skipping around as i was looking back through forums on something about that blank key....it is mapped to Macro 20 which as good a number as any.....Seeing as the Program wing doesnt have a blackout button...and the Key is blank anyways....I have set it as a Macro to be my Blackout toggle....With some big labels on screen in magic sheets to remind me when i am in a BO. maybe ill find an even better use for it one day. Thanks.
