Media File Selection - Arkaos Media Master
When the change was made that requires the use of the [SHIFT] key for fine control of fixture parameters, there was some talk of fixing things so that programs like Arkaos MediaMaster would play better with the changes.
Before the change, if I was trying to select a media file, all I had to do was increment the encoder by one detent and it would change the folder selection or file selection by one. As it stands now, I have to hold down the [SHIFT] key to get this fine control.
Is this ever going to be addressed, or is this just going to be the facts of life from here on in? I sure would like it to work the way it used to.
