Select channels in part cue
Is there a way to select channels active in a Cue part?
Command "Query Cue 1 part 2 Moves Only" will result in selecting all channels in the full cue, the same as command "Query Cue 1 Moves Only" would.
We are using software 2.3.1. Is this a bug in the software or is there a different syntax we should be using?
Thanks in advance,
Jasper
