Hey all,
i'm trying to setup a foot switch to trigger an Element. What i did so far:
Soldered (and checked) the cable for the footswitch, so that it connects Pin 1 against 14/15 of the Sub-D Connector if it is triggered. As it is a dual foot switch i used Pin 3 connecting to 14/15 for the seccond pedal.
I checked in shell that Group 1 and the Adresses 1 thru 4 are selected as it is the default setting.
In setup/show control i checked that analog inputs are enabled
I created 2 Events that have Group 1 as source and Address 1/2.
I tried then several actions with cues or subs or Macros. None of them did work.
Is there a way to see if the trigger does get to the desk?
Did i miss something?
Thanks in advance for any help.
Philip
