When I'm updating cues, I often get the blind cue cursor separated from the live cue cursor. I've figured out one action that consistently causes it to happen: update the TIME on a cue in LIVE mode, e.g. TIME=1. Then execute "Timing_Disable_Go 0" to cut to the next cue LIVE. The blind cursor remains on the old cue. This does not happen with regular GO, only Timing_Disable_Go. How should I be doing this to cause this not to happen? When I do a BLIND LIVE before Timing_Disable_Go, it will resync the cursors. However, if I insert BLIND LIVE in a macro before the Timing_Disable_Go, it doesn't work at all. If I insert it after Timing_Disable_Go, it seems to clean up the problem. How is this supposed to work? What command should I be using for cut forward if not Timing_Disable_Go? Where is this information in the manual?
