Mistakes in the EosFamily_v2.3.0_OperationsManualSupplement_revA
Pressing ";" posts "patch" to the command line and double tapping it takes you to the patch display. NOT “shortcut list”
Mark is "k"
"'" (apostrophe) is filter mode
Macro 810 is listed as control alt 10 – should be control alt 0
“cia hide” is not f5.
"[Shift] + [At], [Shift] + [Enter], and [Select Last] can now be used to loop through commands five times." Not really.
The first press of [Shift] + [Enter] will post the last command line, unterminated.
[Select Last] and [Shift] + [Enter] loop through the last 5 sets of selected channels, cycling in opposite directions. [Shift + At] will repost the previous channels and parameters. It should be noted that double pressing [select last] to repost the last command line, unterminated doesn't work any more.
Channels in use: Maximum channel level is the maximum channel level used, not the maximum level possible.
