Rem Dim Bug
Hi
Running Eos 2.3.1.9.0.12 and if I Rem Dim to any particular lights whilst sitting in a cue in which has my House Lights programmed into it, the console will switch off the House Lights by including them in the Rem Dim command, despite the fact that my House Lights are still pushed up on a HTP submaster. This is a fairly boring issue as I keep plunging the house into darkness mid tech and having to lunge for the Sub to take it down and push it back up in order to restore the House Lights...
Any help/workaround you could provide (short of Shielding the sub as I still want it to follow Cue data when I pull the Sub down) would be greatly appreciated! I can email across a show file if needed...
Many thanks
Paul
