(see post last year "Altering Columns" and SCR 25691.
Running Ion with 2.3.1, adn RVI with the same.
I believe the above bug still exists. Hiding columns in the PSD won't be restored IF the PSD screen is expanded onto the 2nd screen.
ESC and click hides columns.
Shift and Select will restore HIGHLIGHTED PSD screen columns
Recalling snapshot WILL NOT restore columns.
Going to another snapshot and coming back WILL restore columns
If columns are hidden on expanded displays, they don't come back at all. Only through a deep clear from Shell will they re-appear.
On the RVI:
Shift Ctrl Enter and Z Ctrl Enter both work to restore columns on the PSD.
The Live split table (channels and cues) doesn't responde to Shift Ctrl Enter or Z Ctrl Enter. the channel display changes, but the columns remain hidden.
Live split table: snapshots recall doesn't work.
Channel page with the single PSD at the bottom: Snapshots only work if you go to a different snapshot and come back.
Shift Ctrl E doesn't work.
Rebooting doesn't work.
Only the deep clear restores the columns.
Thanks. Andrew
