Just wanting to customise which attributes I'm seeing on the Live or Blind screen. On a console I'd hold the "Param" key and select/deselect in the CIA, and on Nomad I've been using the 'E' shortcut key but that's obviously been re-purposed in 2.3. On the Console Shortcut Keys document Parameters (CIA) no longer appears. Is there something else I should be doing instead?
Apologies if it's something obvious, I don't spend as long on the console as I used to.
regards,
Ric
