Pandoras Box + automark
Hey :)
I asked this question @ the facebook group before, but maybe i will arrive more pandoras box+ eos users here :/
Problem:
First file on layer 1 and second file one layer 2. The third file on layer 1 again and the fourth on layer 2....and so on. All my clips are ( and have to be) in playback mode “ play once “. The last frame of clip one is the first frame of clip 2. For example: Clip one starts in cue 5 triggered by layer one, plays once and ends in its last frame. In cue 6 and 7 i tracked the layer with the “frozen“ frame. In the next cue i try to start the next clip one layer 2. BUT the clip does not start from the beginning it starts in its last frame.
It a problem with the automark. When jump between the cues without timing everything seems to be ok. The “automark cue“ start the clips. So the clip reached its end before the intensity comes up. I also try to use the sequenz patch which only triggers the timline but naturally i have the same problem.
Since now my workaround is to "steal" the marks by setting the layer @ 0,05% with a picture of the first frame of the next clip (Without this content the crossfade would be visible). With more then a handful of clips that gets really awfull an from my point of view no real solution! For cause its also not possible to turn of automark after programming to convert the automarks
Has anybody another solution or workaround?
And why it isn´t possible to disable the automark for individual devises or parameter?
Thank you and regards :)
Julian
