Discrete Time View
Ion
When you want to look at the discrete times of a cue, you hold down the time button.  When you release the button it automatically puts time onto your command line, which is really annoying because then if you need to change anything quickly you need to clear the command line then put the new command in.
Can the time button when pressed for more than, say, 1 second, not put anything on the command line?  If I want the change the time it is pressed quickly.  Thanks
Jay
[edited by: Jay at 5:59 PM (GMT -6) on Mon, May 26 2008]
