Fixture Flicker on Console Exit
Hi all,
We have a (v1 physical) Element board with 2 universes, and all my DMX is on U2, with a few ADJ Pars, several Vivids, and 2 Venue Par64 cans, I also have some wireless DMX fixtures on U2.  It's all single chained with the Vivids at the start of the chain, since they are 5 pin, and a 5 to 3 convertor midline, with the rest wired into the loop and terminated at the end with the wireless transmitter.
I have no issues when I bootup element and load the console, and a show file.  But as soon as I use the CIA (Central Info Area) to exit the console to the ECU (Config Utility Screen) or Power Down the console, I will get random flickering (multicolor) of the Venue PAR64 fixtures.   With my prior software version of Element (2.1) I could just hard shutdown the console, and the flickering would stop..   Judging form other forums here, I thought it may be timing or because we have RDM enabled, so I tried lowering timing, and disabling RDM, along with an update to 2.3.2 (which, BTW, is pretty awesome..), but alas, my flickering remains, and now a hard shutdown of the console is not solving the flicker issue.
Any ideas? (Short of replacing those fixtures, which is going to be a step here soon, but I would still like to figure out the root cause.)
Eric Golpe
