Chan Check with Color Broken -- Intended?
Hi Friends,
One of my favorite tools to ring out a rig w/ scrollers/seachangers/etc was always something like 1 @ 50 Color 5/80 Check, and nexting through.  This seems to have broken with 2.3.  Is this intended?  I know I could do something similar with highlight... but that would involve setting up highlight/lowlight presets before the ringout, and if I don't have a clear view of the stage it doesn't necessarily catch swapped accessories.  Having Chancheck w/ NIPs back would be excellent!
  • Thanks, the feature still works, but the problem is that the [Chan Check] softkey no longer appears after setting the gel from the command line. We will fix this, but until then you can record a macro that just contains the [chan check] command, and use that instead of the softkey.
    Ex: [chan 1 at full learn macro 1 enter chan_check learn]
    [chan 1 at full Color 5 / 80 macro 1] next, next ,next
    RND 0033861: [Chan Check] softkey is not available after setting a gel with the command line
